SW 2008 x32 on vista x32
Hi all.
 I'm using Solidworks to design machines like case erector and case packers,my assemblies are large and SW(not responding)is showing up frequently, I need to wait like 3-5 min, I don't know the reason, I already try several approachse without success so I'm reporting here , maybe someone can at least point me a direction to a solution.
In this case I have 3 subassemblies in flexible so I can simulate the machines movements.
I can open the assembly and rotate it very well.. problems occurs when I start editing parts and rebuilding it.
some times (very remotely) the screen inside SW turn black in drawings.
1521 mates are evaluated when rebuild
parts: 2142
sub-assemblies: 425
maximum depth: 6
number of top level components: 11
number of top level mates: 27
number of bodies: 2469
OS. Vista Ultimate x32 SP1
SolidWorks office premium SP 3.0 x32
Proc: AMD 64 x2 dual core 5000+
nvidia FX7950 softmoded in Quadro FX 3500 drive 7.15.11.7551
Ram: 4x 1GB
Files are not local.
Emerson Bottero
RE: SW 2008 x32 on vista x32
Emerson,
Your files do not look that large. Make sure there are not errors, springs, or lead screws. Clean your temp files and defrag your system. Set your virtual memory to twice your RAM, both the same. I see your Ram: 4x 1GB. I suppose you have 4 sticks of 1 GB each. Windows 32 bit will not see 4 GB. Only run SolidWorks.
If those things do not work, upgrade to x64 and get 6 GB's of memory.
Bradley
SolidWorks Pro 2008 x64, SP4.0
PDMWorks Workgroup, SolidWorks BOM,
Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 10240 MB,
nVidia Quadro FX 3400
"If it ain't broke, you just haven't looked hard enough." Fix it anyway.
If you are running Windows Indexing Service, disable it. If that makes a difference there are ways to fine tune it minimize its effect on SW.
The soft-modding of the VC could be a part of the problem.
Copy the files onto your machine to eliminate any network bottlenecks.
cheers
Hi, im not using springs or lead screws, I cleaned my temp files and the disk where vista is installed is 0% fragmented, my virtual memory is twice my ram already, I know Vista 32X use less than 4GB, about 3.5GB, I've tried to use SW x64 on XP64 but the problems continues.
I did also wath CorBlimeyLimey said and it didn't change the problem.
I notice that when it's (not responding) the cpu used keeps in 55% and when it comes back to normal the cpu used drops to 5%. I think SW is overloading one core of the cpu. any other ideas?
I'm leaning towards graphics card. First, you've modified an unapproved card then compounded it by not using a certified driver. The correct driver for the Quadro FX3500 should be 7.15.11.6250.
Also, working across a network is, usually, more of a pain and tends to be slower than working locally.
Jeff Mirisola, CSWP, Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
I know about the video card, the problem using nvidia game cards is it get slow if you open more than a certain number of windows, that's not my problem, I use SW in video card like that since 2000, I updated the video card drive trying to solve the problem, it didn't changed anything. I also have tried to copy the files to my computer and the problem continues.
I really appreciate all the help but I still doesn't know what to do.
