Strength of ungraded Steel machines screws
Anyone know what can I use for allowable strength or stress for ungraded, zinc plated steel machine screws? Like for example this one http:/ /www.faste nal.com/we b/products /detail.ex ?sku=28141
RE: Strength of ungraded Steel machines screws
You can assume annealed 1010 steel, you can ask the vendor what they recommend, or you can select a screw from a vendor who specifies the material.
JHG
Would that not make it a "graded" screw?
Is that proof, yield, or ultimate stress?
JHG
NASA had to replace thousands of fasteners on the Space Shuttles once they realized they had "ungraded" screws.
If you get "ungraded" screws, you get what you get, and and you never know what you might get.
Get it?
I have worked with Fastenal in the past and they are always will to help.
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
http://
Ted
Got it!
Try the FAQ's of the forum.
Rod
