Separate Sources in Parallel?
Is there any repercussions in placing to separate sources in parallel like in the case of a double ended switchgear fed from to separate external utility sources (say Utility #1 and utility #2)..two separate circuits. Most of the utility interconnections I encountered so far was in the form of a ring connection and two lines enter a substation.
RE: Separate Sources in Parallel?
I've seen this done on a temporary basis, but only under direct supervision of the utility operations folks.
1 The 2 sources MUST be in phase a.k.a. in synchronisim
2 You will substaintially increase the amount of fault current. You must make sure your switchgear can handle it
3 If the 2 services are fed from transformers then the transformer impedances must be the same. If they have LTC's you will need joint control for them
3 For faults beyond your system, the fault current would flow thru your switchgear bus. You should install directional overcurrent relays to sense this condition and open the faulted feeder
What Alehman said.
It will be problem with same utility, Substation feeded from separate substations of same utility.
Regards.
Slava
