stretching a circle
stretching a circle
I am new to autocad and am having a lot of problems in editing existing drawings. For instance how can i modify the diameter of an arc? If i ty to stretch it, the whole arc moves and the dimension value cannot be modified by entering a new value in the properties box.
The drawing I am trying to edit is attached. I am trying to reduce the diameter of the arc from 1.008 to 0.65
Mike
Mike
RE: stretching a circle
which Acad-version are you running?
http
Properties palette or grips or "_varia" or...
Lothar
ADT 2004
Don Phillips
http://worthingtonengineering.com
Zuccus.
