Gas Struts/Springs placing
What is the best way to figure out the position of a gas strut on the inside of a carcuss? i.e the position of the two ball hinges that connect the Gas Strut.
RE: Gas Struts/Springs placing
You can also apply the methods of three-four bar linkages to come up with the same result, then model that in some software package to validate your computations. Same-same as what I did.
Good luck with it.
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
