looking for material type for DIN 1804 5W
print calls for the nut to be made to DIN 1804 and the material is listed as steel( 5W). I don't know what the 5W is. I would be greatfull for any help
                thanks
RE: looking for material type for DIN 1804 5W
This is an ancient DIN standard, last changed in 1971.  The 5 means class 5 according to DIN 267 Part 4, which is now obsolete, having been superceded by DIN EN 20898-2 (same as ISO 898-2).  The W means unhardened.  Just about steel can be used to meet the property requirements of ISO 898-2 class 5.  The following link has additional information:
http://www.bossard.com/techinfo/en/extdoc/TT_09-09.pdf
thanks. this helps a bunch.
