Transformer Temporary Replacement
Can we temporarily replace 5 MVA 34.5KV-Delta/6.6KV-wye Transformer with a 10MVA 69KV-Delta/13.2KV-wye Power?
Based from the transformation ratio, assuming the 10MVA at nominal tap, if 34.5kV is induced at the 69kV primary, this will result to 6.6kV at the secondary. Are there any repercussions to consider?
RE: Transformer Temporary Replacement
Bill
"Why not the best?"
Jimmy Carter
