Pressure vessel shell thickness calculation
I've found on the Outokumpu site a very useful tool to calculate the shell thickness for vessel based on ASME VIII and EN 13445 using different steel materials (duplex, 316...). and other calculation tools.
Is possible to compare the different thickness for different materials.
this is the link, then use the Design links.
 http://www.outokumpu.com/applications/documents/start.asp
Hope you'll find it useful
S.
Metal Corrosion
