Max HW/D = 1.5 for culverts - Why?
A number of culvert design standards say that the maximum headwater depth is limited to 1.5 x diameter of the culvert. Can anyone explain the basis for this criteria?
We're designing a replacement culvert for an old 3-ft diameter culvert that collapsed. If we replace it with another 3-ft diameter pipe, the headwater will not overtop the road (not even close), but if we use the criteria that HW/D cannot exceed 1.5, then a 4-ft diameter pipe is needed. I've seen this design criteria in several publications, but haven't found any reasoning or justification for it. If anyone knows, I would appreciate an answer.
RE: Max HW/D = 1.5 for culverts - Why?
In the jurisdictions that we design for, 1.5 (or 1.2 some places) is not a limit, but a design guideline for selecting the size of the pipe for the application. If you do not have overtopping, you can certainly go higher, especially with a 3' diameter pipe. If it was something like wanting to use a 1' diameter pipe where you should be using a 3', that would be kinda iffy. If your HW/D is getting up around 4 or 5, I'd definitely look at the larger pipe, but if it's 2, and you're thinking that 1.5 is a hard line, I wouldn't think you would need to increase the pipe size.
My guess for why 1.5 is used as a guideline is that it scales with drainage area, and for areas where design flows are not maximum flows, it gives you a pipe that won't be too badly undersized for the maximum flow, but will still provide a high enough velocity for normal and design flows.
Of course, either your client or the local permitting authority will be the final word about whether they'd accept the computations.
good luck
What's the difference between orifice control and inlet control anyway?
See page 175 of this text:
http://isddc.dot.gov/OLPFiles/FHWA/012545.pdf
There's also some comment on flotation that may be appropriate, depending on your endwall.
Highway27 - Your reasoning makes sense to me, especially since the regulatory agency's design manual says nothing about the HW/D, just basing allowable headwater on being some distance below the road. I'm going to run comps for various diameter pipes to compare HW/D, then discuss it with our client and the agency.
Regarding inlet control vs. orifice control, I believe RWF7437 is correct. I took a look at my old copy of HEC-5 and it shows culvert flow profiles, one of which is for unsubmerged inlet control, where the HW is below the top of the pipe.
Thanks again.
