Assembly Mate
Assembly Mate
How I can connect edge on face?
RE: Assembly Mate
RE: Assembly Mate
Use a Connect relationship between the first extremity vertex of your edge to the target plane (V20 SP7 helps because vertexes regained higher priority). Then connect the other extremity vertex to the same plane.
You can also draw a sketch on the plane and use the Axial align relationship between the sketch segment and the edge.
HTH,
Fred
RE: Assembly Mate
Thanks for solution.
Is there any direct way instead of using two extreme vertex or sketching? I know, even elementry cad packages have this ability.
