ALUMINIUM DISSOLUTION
What is the concentration of NaOH required in a caustic/water solution to cause maximum dissolution rate of aluminium?
We currently use 25% NaOH to dissolve aluminium from extrusion dies.
RE: ALUMINIUM DISSOLUTION
Aluminium dissolution will increase with increasing pH, so a concentrated NaOH solution should provide maximum dissolution.  However, you may not want to handle concentrated NaOH, so use the maximum concentration you are comfortable with.
