Linking Dumb 2D prints to "new" Solid models ?
Gentlemen,
I am looking for a way to link imported CADKEY "dumb" prints to "new" solid models of the same parts created in Solidworks, so the dumb print will follow and be linked to the "new" solid model in PDM.
I do not need the dumb print to change with the model, these are old prints and old components that more than likely won't change,and if they were to, then I would recreate the print in SDW.
We have a bunch of older components that we make that we use in new products,so we model them in solidworks to use in assemblies, but the prints and lower level parts are the same. I want to try to get them to reside in the same location in the vault...
RE: Linking Dumb 2D prints to "new" Solid models ?
Most PDM systems have a means to "manually" create links between documents.
This is exactly my question???
How to accomplish this??
I have been at this for most of the afternoon...
In PDMWorks Workgroup, you can right-click on a part and select Add Attachment, then browse to the file.
Eric
Eric,
Thanks.
However, you can only add attachments to non-solidworks entities.
I am "converting" the CAD KEY prints to a .DWG or .sldrw first so I can edit them, if need be, in a Solid works environment. We are trying to phase out CAD KEY.
This "conversion" make them a solid works entity, and  disallows me to attach them to the 3D model file...
A quick and dirty way of linking your "dumb" drawing to your SWX model would be to insert a view of the SWX model (an ISO view would be pretty benign).  If you don't want the new view, I believe you could hide it and still maintain the link.
I did think of doing this...
I was hoping to link these with out having to do this...
Thanks I will keep this in my back pocket...
What does PDMW do with linked design binder docs?
