Copyclip and pasteclip in 2002 will not work....
Had this happen before, keep forgetting how to correct it. Any ideas.
Copyclip seems to work it will let me select entities, but pasteclip pastes nothing. Is there a system variable or option setting im missing.
RE: Copyclip and pasteclip in 2002 will not work....
is it your own *.dwg, or did you get it from ACAD 2007?
    PICKFIRST variable on 1.
    Layer unlocked?
    Proxies (from another CAD) inside your drawing?
    Tools -> Options User Preferences Tab -> "Windows standard
    accelerator keys"
    "_recover" / "_audit"
Lothar
ADT 2004
We've run across something like that too, and it ended up being something corrupted with the dimensions.  When we copyclipped everything except the dimensions, it worked fine.  With the dimensions, would NOT paste, for anything.
Audit found no errors, never did get it to work with the dims.  Just had to work around it, and add whatever dims were necessary in later.
