Design Binder
Design Binder
To me, a convenient way to add files to the Design Binder, especially when there are multiple files, is to drag-drop them from the windows explorer, but it seems like the only way SW will do this is to make them linked attachments. This, in my experience makes the requirement that the files must be copied and/or moved with (accompany in some way) the SW file in order to access them. I've tried to CTRL drop, SHIFT drop, anything I can think of to change the mode to embed, but can't. Is there an easy way? or do you just have to one-at-a-time attach the files through SW attach interface?
Mike
Mike
RE: Design Binder
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
RE: Design Binder
Thanks for info,
Mike
