exporting solidworks part file
hi!
i am looking forward to export a part file to the gambit software from solidworks.
I have been able to export 3dpart files into gambit by first saving the part file from soldiworks to iges file and then importing the same.
but i want to create an airfoil and do the 2d meshing in Gambit software. i thought if i could create sketch in the solidworks and without extruding and save it as iges or other file formats. but it did not work.
Gambit accepts ACIS, STEP, IGES, pro-e step and some other types
can you kindly help me out with this
thanking you
kartik
thanking you
kartik
RE: exporting solidworks part file
- - -Updraft
If you can not get SW to export curves in IGES, try making a simple planar surface for your section and export that.
