Fire rated floor deck
Does anyone have a detail for a load bearing metal floor deck fire rated 2hr from both sides.
RE: Fire rated floor deck
Any steel beams or just concrete over metal deck?
Steel beams fire sprayed, no concrete just metal deck///
Bare metal deck without concrete fill has no fire rating. There is no tested UL assembly for bare metal floor deck with spray-on fireproofing.
The closest thing might be metal roof deck w/ spray-on plus roofing but you cannot use this assembly if you have no roofing.
I see no way that you can achieve the 2 hour rating as you are asking. I think that you might be stuck adding concrete plus spray-on.
