Altivar 61 vfd parameter correlation to Altivar 21
I am looking for parameters in a Altivar 61 VFD manual that would correspond to parameters 241 and 242 in a Altivar 21 vfd.  The Parameter F241  provide a means to stop the drive when the analogue reference signal goes below a certain level  and then F242 provides a hysterisis so that when the signal comes back a + your hysterisis,  it will restart.
RE: Altivar 61 vfd parameter correlation to Altivar 21
If you can set the ATV61 up in PI(D) mode then you could use the Sleep function that will perform as you need. But you need PI set within the drive.
