sorting arrays
sorting arrays
HI, I TRY THIS SORT, SEE THE OUTPUT AT END
THE RECORD #15 AND 16 NOT IN ORDER, THANKS FOR YOUR HELP
200103=caso1
01167=falta1
"A" or "I"=status1
For Loop1 = 0 To total
pos = Loop1
For loop2 = Loop1 + 1 To total
If caso1(loop2) = caso1(pos) And status1(loop2) < status1(pos) Then
pos = loop2
End If
Next loop2
If pos <> Loop1 Then
Tmp = caso1(pos)
caso1(pos) = caso1(Loop1)
caso1(Loop1) = Tmp
Tmp = falta1(pos)
falta1(pos) = falta1(Loop1)
falta1(Loop1) = Tmp
Tmp = nombre1(pos)
nombre1(pos) = nombre1(Loop1)
nombre1(Loop1) = Tmp
Tmp = status1(pos)
status1(pos) = status1(Loop1)
status1(Loop1) = Tmp
End If
Next Loop1
THIS IS THE INPUT
20010301167,ROBERTO ADAMES,A
20010301337,MAXIMINO MENDEZ,A
20010301509,CARLOS RIOS,A
20010302143,FLORENCIA MORALES,I
20010302242,ISRAEL ROMAN,A
20010302471,LUIS BARRETO,A
20010302948,AWILDA CUBERO ,I
20010303205,CONSORCIA HERNANDEZ ,A
20010303277,HECTOR NIEVES,A
20010303919,EMILIO MORALES ,A
20010304085,CARLOS NIEVES ,A
20010304441,LUIS IGARTUA,A
20010305264,LUIS GIRAUD ,A
20010305326,TRINIDAD RIVERA ,A
20010320014,JOSE MARTINEZ,A
20010320056,ANTONIO OCASIO,A
20010320083,ANTONIO PEREZ,I
THIS IS THE OUTPUT
20010301167 ROBERTO PADIN ADAMES A
20010301337 MAXIMINO CRUZ MENDEZ A
20010301509 CARLOS SOTOMAYOR RIOS A
20010302242 ISRAEL PEREZ ROMAN A
20010302471 LUIS PEREZ BARRETO A
20010303205 CONSORCIA DEL VALLE HERNANDEZ A
20010303277 HECTOR NIEVES NIEVES A
20010303919 EMILIO MORALES VELEZ A
20010304085 CARLOS ROSARIO NIEVES A
20010304441 LUIS SOTOMAYOR IGARTUA A
20010305264 LUIS ORTIZ GIRAUD A
20010305326 TRINIDAD LOPEZ RIVERA A
20010320014 JOSE GONZALEZ MARTINEZ A
20010320056 ANTONIO RIVERA OCASIO A
20010302948 AWILDA RESPETO CUBERO I
20010302143 FLORENCIA PEREZ MORALES I
20010320083 ANTONIO VILLANUEVA PEREZ I
200103=caso1
01167=falta1
"A" or "I"=status1
pos = Loop1
pos = loop2
End If
Next loop2
Tmp = caso1(pos)
caso1(Loop1) = Tmp
Tmp = falta1(pos)
falta1(Loop1) = Tmp
Tmp = nombre1(pos)
Tmp = status1(pos)
End If
Next Loop1
THIS IS THE INPUT
THIS IS THE OUTPUT
RE: sorting arrays
CODE
