Select Export Coordinate System Through API
I have a macro to save x_T/PDF versions of files to a specific location.  The macro works fine in that the right files get saved in the right places.  The question is how do I change which coordinate system to use for export?
Manually, it is a simple switch in the export dialog options, but I cannot find any API calls for changing it, only one that returns the name of the current coordinate system.  Any suggestion on how to change this parameter?
 - Mark
