Coordinate dimension table
I was wondering where you can change the default number of decimal places that the table uses when using the coordinate dimension table command. I understand how to use the command but I cannot seem to change it from 2 to 3 place dimensions. The table also just brings in dumb text, so changing the fields line by line to 3 places is not an option. Thank you in advance to anyone that can help with this. BTW I am using Catia V5 R17.
RE: Coordinate dimension table
