Max distance for Split A/C units
What is a max rule of thumb for distance between the condensor and evaporator for typical small (around 10 ton) units on commercial retail buildings? Can refrigerant lines be oversized to reduce pressure drop? Is there a vertical distance rise/fall limit? Should the unit be ordered with any special options?
thanks,
thanks,
RE: Max distance for Split A/C units
Attached is some helpful information provided by Carrier.
Andy W.
HVAC68
