recharge or renew magnetic strength of magneto rotor
I am trying to recharge or renew the magnetic strength of a magneto rotor. The magnet is made up a stack of thin metal plates laminated together and then riveted into the middle of a shaft which allows it to rotate. The usual way to do this seems to be to expose it to very strong magnetism from a big electromagnet for a short time. I don't have a big electromagnet. I'm wondering if it would work to use smaller magnets for a longer time to accomplish the same thing. I have a couple of welding magnets (magnets to hold parts in position for welding) and I'm wondering if I just stick them on the magneto rotor and leave them there for a week, will they increase the strength of the magneto rotor?
Thanks for any help.
RE: recharge or renew magnetic strength of magneto rotor
According to the hysteresis curves (the full curve, not just the demagnetization quadrant), remagnetization is caused through the exposure to a large magnetic field, which gets the domains in the magnet material to line up and produce a magnetic field of their own. Time is only a secondary factor, only necessary to allow the domains time to rotate to the amount the strength of the applied field dictates.
Depending on the materials of the various magnets, the welding magnets could increase the rotor strength, but I doubt it will fully restore the possible strength of the rotor material.
Assuming the laminated portion is the permanent magnet:
1) Time is not a factor. Magnetization occurs very quickly, within seconds. Leaving magnets sitting for a week makes no difference.
2) The best way to remagnetize is with a fixture that'll make contact with and charge all the poles on the rotor simultaneously.
3) Since it sounds like you won't be able to obtain a magnetizing fixture, there is a small chance that you can restore some of the magnetism by using permanent magnets, one on each pole, with alternating polarity. Try to match the size of the magnets with the pole face and try to go with rare-earth permanent magnets (no assemblies, such as welding magnets).
If you want it done right and done well, then send it out to someone who does it for a living. You'll save time and money in the long run.
TTFN
Thanks again for any help.
Mark
Mike
http://en.wikipedia.org/wiki/Squirrel-cage_rotor
TTFN
The magnet in this patent is a very small portion of the rotor.
TTFN
