Stiling Well
Stiling Well
Dear All,
Will someone please tell me why stilling wells/slotted gauge wells have so many holes in the side to accommodate for the pressure and vacuum of the tank being filled or drained. Surely just a couple of holes near the top of the pipe would be sufficient depending on the filling and discharge rates. I have always found these to be over designed and would like some opinions.
RE: Stiling Well
RE: Stiling Well
Holes are cheap...
Extra hole provide insurance against gunk build-up and assure that tank cleaning cycles are not controlled by device build-up.
-MJC
RE: Stiling Well
DB
RE: Stiling Well
You put 20' of water in the tank. Then add 20' of oil. Since all of the product has to enter the stilling well at the bottom, when you're done, the stilling well is full of water while the tank is half full of water and half full of oil. Due to different densities, the level inside and outside of the still tube could then be substantially different.
Not that this exact scenario takes place, but it seems to be the intent, that for accurate measurement of the level, the composition and temperature of the product in the stilling well needs to match that of the product outside at each level.
