circuit breaker trips starting a dec 125 AVR
I got a 1700 kva generator and i got a dec 125 avr, we have C curve circuit breaker and trips, the thing i want to know if i could expect a trip from the magnetic side of the circuit breaker... cause of the inrush current?
RE: circuit breaker trips starting a dec 125 AVR
Bill
"Why not the best?"
Jimmy Carter
No inrush but the time to reach full current may vary with different circuits.
The AC inrush will approach the normal DC current.
I don't think that you will see a DC inrush, so there should be no inrush reflected back to the AC supply.
A partially shorted field will cause higher than normal AC current.
Bill
"Why not the best?"
Jimmy Carter
