Dissimilar welding of P1 and P8 materials
Dissimilar welding of p1 to P8 materials for a pressure vessel (ASME VIII div.1), plate thickness is 40mm.
(1) If materials are used for pressure parts, what is the preheat temperature I can use? Can I do PWHT for them?
(2) If materials are used for Non-pressure part, what is the preheat temperature I can use? Is PWHT required by code?
ASME VIII div.1 is used for the pressure vessel construction.
Please advise. Thanks.
RE: Dissimilar welding of P1 and P8 materials
Comeback with the specific materials and thicknesses.
Pressure containing base metal: 34mm
Non-pressure containing base metal: 48mm
You have found your preheat requirement answer above for pressure retaining carbon steel material used with similar material or in a dissimilar metal weld (DMW) joint application (See Table UCS-56 in Section VIII, Div 1). The key is to set a maximum interpass temperature of 400 deg F for use in a DMW to avoid exposing the P-No 8 to high heat input.
For non-pressure retaining CS material that is welded to non-pressure retaining austenitic stainless steel, this advice would still hold for the CS and thickness. I like to use ASME Section VIII, Div 1 preheat requirements even for non-pressure retaining applications to remain consistent.
Would you recommend the PWHT for the non-pressure carbon steel? Is ASME VIII Div. 1 UCS56 applicable for Non-pressure part?
Appreciate.
Thanks.
If the non-pressure part is P-No 1 material and exceeds 38mm in thickness, PWHT would be required. Now, if you are going to be welding this to a P-No 8 base material in a DMW joint, you should butter the P-No 1 weld joint with 309, PWHT the P-No 1 base material after buttering, and complete the weld joint using 308 stainless steel with no PWHT.
Thanks for you helpful advice.
http://www.cspec.com/
