Toggle for Manual Entry?
Is there a way to have a toggle button or drop-down list of some kind that would allow either manual entry or a lookup value? I have never used VBA, so excel formulas would definately make me happier, but I don't know that it can be done.
Basically, say I wanted to create a spreadsheet for simply supported beam deflection. I would like to be able to choose from a list that I could create of standard wide-flange beams OR choose "custom". If a standard beam is choosen, then the properties, such as cross-sectional area, moment of inertia, etc could be pulled from a table on a different sheet. If "custom" was choosen, these values would be manually entered.
I can do this now if I have the lookup function for finding the value, but then if I choose custom I have to type over the formula. Then, if I want to use the spreadsheet later for standard beams my lookup formula is gone. Of course, I could have the "custom" values in different cells and just use them if the ones for standard values are blank... Just wondering if there was a good way to do this...
-- MechEng2005
-- MechEng2005
RE: Toggle for Manual Entry?
ht
Custom is simply another choice. The values in the lookup table for custom are filled from a separate area at the top of the input/output sheet.
