changing sheet formats?
I have created a two page blue print using SW08 and have just noticed I used the wrong sheet format. Is there a way to change from one format to another without having to recreate the blueprint?
RE: changing sheet formats?
RMB on the sheet
Select Properties
Select the sheet format you wish to use
Click OK
cheers
thank you.
