Vertical Multi-Stage Pump
I am looking for a vertical multi-stage pump for the duty of Flow 97.2 Lts/s, 82m Head.
I can't find one from the usual sources, anyone came across one of these monsters?
RE: Vertical Multi-Stage Pump
Based on what you've provided, Goulds would have several choices.
Plymouth Tube
Anyone know of a manufacturer that makes this type of pump to this size?
Try Afton Pump
http://www.aftonpumps.com/pump_sel.cfm
Certainly, there would be others. I would also check out Travini (sp?), SIHI, etc.
