multi roll plotters
multi roll plotters
multi roll plotters
We have a multi plotter with two rolls, one mylar, and one paper.  How do I set up the plotter in NX3 to be able to select either roll?
RE: multi roll plotters
Can you define it as the same printer twice set one definition to the paper roll and the other to the mylar. I don't know if that will necessarily work but it might be a chance.
Good idea that two roll system though. We used to have to change the rolls and re-calibrate a mylar plot every time. It was a great waste of media ans as you probably know Mylar isn't cheap! wink
Cheers
Hudson
there are some extended parameters for roll/tray selection:
on similar hpgl driver:
PARA HPGL INTRAY = ROLL1 <-- to specify Media Source Roll 1
^PARA HPGL INTRAY = ROLL2 <-- to specify Media Source Roll 2
on Rtl drivers :
  +MS1    <-- to specify Media Source Roll 1
  +MS2    <-- to specify Media Source Roll 2
control in
In the Printer Setup form, select "Advanced Options"
... setup 0ne plotter/printer for each roll...
