RIGID BODIES AGAIN
RIGID BODIES AGAIN
RIGID BODIES AGAIN
Does anyone know how to make a rigid body out of an imported orphan mesh ?
RE: RIGID BODIES AGAIN
Unless someone has a clever answer of meshing the outside with rigid elements, you could always make the properties of the part very stiff by using a very high Young's Modulus.
corus
I know you can convert the solid mesh into shield mesh.
Wonder if you can then change the shield elements into R3D4 elements in keywords.
Hoever, I haven't tried it myself, it is just an idea.
Opp spelling mistake..
*Shell not shield
yoman228 is right. you can change element formulation in abaqus input file
put the elements in a set and use the *RIGID BODY utility, I don't exactly remember the syntax, but its very straight forward. Check the manuals.
Hi again this is how you should do:
1. Put all of the elements in one element set: *ELSET,ELSET=ORPHAN_MESH_TO_RIGID
el1, el2, ...,eln etc.
2. Use the *RIGID BODY facility:
*RIGID BODY, REF NODE=NNNN, ELSET=ORPHAN_MESH_TO_RIGID
(NNNN is a reference node for the rigid body)
And then you have yout rigid body.
