Pumping against a sand filter
Hello everybody:
For a particular industrial process, it is needed to pump out an effluent with solids in suspension to (against) a gravel and sand filter of around 16 feet height, 5 ft x 5 ft and, inside a pipe, the filtered liquid will flow out of that sand filter by gravity to a trench.
The questions are: how to relate the losses in the sand filter to the losses in the discharge of the pump, as if it was pumping through a discharge pipe? Which is the proper way to calculate the losses in the sand filter?
Your comments are welcome. Thanks.
RE: Pumping against a sand filter
If these figures are not available you will need to flow test it to give the head losses before you can finalise you pump selection etc.
If there isnt then Wastewater Engineering by Metcalfe and Eddy gives a methodology for estimating losses through clean and dirty filters. These calcs are quite sensitive to assumptions and data available. I would compare this with data from existing sites and speak to suppliers of the sub layer distribution systems or other types of sand filters.
