Autocad 2002 driver for HP1050C
My problem is the following:  Before in autocad R14 my plotter an HP1050c would generate ink on the drawings on both swipes.  now in Autocad 2002 the plotter will only generate ink on one swipe, therefore slowing the plotting process. Is there a setting in AutoCad 2002 or is it the driver???   currently im using the driver supplied by AutoCad 2002 in the CD..
RE: Autocad 2002 driver for HP1050C
You can try setting the plotter resolution and other properties from within AutoCAD.  You will probably find it at Plot/Plot Device/Plotter Configuration/Custom Properties etc.  Otherwise it is a driver problem.
try HP's site to D/L autocad 2002 drivers.  The link below should take you to the page.  I have the same plotter but still use acad14.  acad 2k versions are a pain for plotting.  Good luck.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNum=C6074B&prodName=hp+designjet+1050c+plus&locale=en_US&taskId=8418&taskName=download+drivers+%26+software&prodTypeId=63002&prodSeriesId=24023&prodSeriesName=hp+designjet+1000+series
