ACME THREADS
ACME THREADS
ACME THREADS
Can solid edge produce acme threads?
RE: ACME THREADS
I'm not sure if it's available in the hole command (I'm assuming you've already looked), but I would suppose one way of doing it would be to use the Worm Gear Designer... or a helical cutout with a 29 degree slope, patterned in a circle.
Hope this helps,
Martin
RE: ACME THREADS
You can add the thread details to the Holes.txt file, then you will be able to select it as for other threads
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
