Rectangular pattern
Rectangular pattern
Is it possible to use a rectangular pattern to pattern a feature (hole) where the patterned instance is say over 1" and down 1"? They would be essentially on a diagonal from each other.
R18.
thanks...
R18.
thanks...
Fighter Pilot
Manufacturing Engineer
RE: Rectangular pattern
I won't say what I could do in my old CAD system but this would have been easy w/ one command. Oh well....
Thanks...
Fighter Pilot
You should now see the orginal hole and 3 ghost holes, all you have to do now is disable the holes you don't want by clicking the little dot in the middle of each hole.
or,
Create the pattern with the x, y and suppress the superfluous entities?
Sweet!!! That's exactly what I wanted to do. Now I have some meaningful dimensions to drive the pattern. Now that it's explained to me I can remember clicking on those ghost holes to remove the instance of the pattern.
Thanks...
Fighter Pilot
