Create datum plane in CATProduct?
Maybe it's me but can't you create a datum plane in a CATProduct?
If not, I'd like to know the reasons why and any workarounds.
R18
Thanks...
Fighter Pilot
Manufacturing Engineer
RE: Create datum plane in CATProduct?
What we do is insert a part and call it axis, use the fix command.
Now you can use the axis system within the part as a datum.
On that part I would also recommend that you in the part property untick "visualizs in BOM"
