tolerance for lean of retaining wall
Hi, I am involved in an investigation regarding a leaning retaining wall. I am trying to write a report and am wondering if anyone knows offhand a code based tolerance for angle of lean (ie. what is/is not acceptable), especially in a Canadian context.
RE: tolerance for lean of retaining wall
I don't know how much the wall needs to actually move to achive the active pressure, but if it is cantilevered retaining wall, it is supposed to move....... again, I don't know how much.
The wall is actually rotating or falling over due to the pressure of the soil behind it. Its very obvious to the naked eye; we had it surveyed and its about 8 degrees off a vertical reference line. In other words, an overturning failure. I suspect it was backfilled with the local clay instead of a granular fill.
I was assuming that there must be some kind of tolerance that I could compare it to in my report as even a "properly" designed and constructed retaining wall would be resonably be expected to lean a little bit either backwards or forwards.
Retaining walls backfilled with clay are very complicated things. If the clay shrinks and swells with moisture change, cracks will collect debris, changing the volume. Where you are the cracks will also collect water and freeze. Thus the movement is often gradual (creep) and can continue to move for years.
