extrude boss from another feature
I was trying to extrude boss the end result of another feature, as example: after having a revolved boss with thin layer, it gives a solid cylinder with wall thickness 20 mm.
if i want to extrude this wall around the cylinder for 50 mm, it opens a new sketch for me to draw and i just want to use what i have coz sometimes its a complicated curve that will not exactly fit on the exsiting one.
Is there a way to specify to use the existing wall instead of let me draw a new scetch?
RE: extrude boss from another feature
-handleman, CSWP (The new, easy test)
I used Convert Entities but i thought that there is another way to do it.
Thanks again
Sounds like a revolve feature rather than extrude, but if it is extrude you might be able to use Insert>Face>Move without having to create a sketch.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
