UG-NX4 CAM => Unable to visualize the holder
The tool has been retrieve from the Tool library,
but the holder details are missing, only tapered (conical) shape is been viewed.
If the tool is selected from the tool library is the holder automatically loded? (i.e., is the holder selected form the holder library or tool library automatically)
If not how to load the holder automatically while the tool been is selected from the tool Lib?
plz help me
plz help me
RE: UG-NX4 CAM => Unable to visualize the holder
When I export a tool to the library with a holder, when I retrieve the tool the holder comes with it. I tried this on NX4.0.2.2 and it works fine.
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
2) I have no idea how the tool was created,
but the tool data details was found in the following .dat file
File location ---> UGS/NX4/MACH/custom/library/tool/metric/tool_database.dat
(Note: file attached, only the tool data details, not the entire file)
2. On the tool dialog select Export tool to Library
Select the tool type and hit OK
3. Select retrieve tool and select the tool you just exported. It should come in with the holder.
As long as you have write access to the tool database you should be able to add tools to the library.
John Joyce
1675 Larimer St.
Denver, CO
www.myigetit.com
