Produced water degasser
I am attempting to design a produced water degasser.  The water will be first separated in first / second stage 3 phase separators and then pumped to a break tank.  After this the water is pumped through hydrocyclones to reduce the hydrocarbons to 30-40ppm.
The produced water degasser will receive approx 45,000bbl/d of water. What I am really interested in is a required liquid residence time for the liquid in order to size the degasser.  Would this usually be a vertical vessel?
Cheers
RE: Produced water degasser
For degassing you should use a horz. vesseæ in order to minimize the travel distance for bubbels and maximize contact area.
You company engineering standard may state something about residense time?
If not GPSA/API has some guidelines.
Best regards
Morten
