MONEY COUNTING MACHINE HEAT LOAD
I´m doing a preliminary heat load estimate for a large bank´s money counting room. They are planning to use some kind of industrial-sized counters which even use vertical tank air compressors for some purpose. Any idea on where to obtain info regarding heat output or cooling requirements for such equipment? Thank you
RE: MONEY COUNTING MACHINE HEAT LOAD
TTFN
There still no final selection of the counting equipment manufacturer. When you talk about breaker settings, is that used to calculate volt-amps and then get an approximate heat equivalent? Thank you.
TTFN
