Anchor Chair Repad-API 650 tank
Hello Everyone
I wonder if any one can advise a reference to help in sizing the repad at anchor chair. Repad sizing is required by a third party inspector. Repad was selected due to high stress at shell caused by anchor chairs.>25,000 psi.
Best Regards
RE: Anchor Chair Repad-API 650 tank
As an approximation, treat the repad as an anchor chair of equivalent height and width.
Is there any document or standard to be used in repad sizing , as this sizing is required by third party inspector and approximation won't work. I know ASME VIII Div II has these calculations for pressure vessels.
Best Regards
The approach typically used is listed as a reference in API-650, I believe- books put out by AISI.
I have had the same question. I'm still looking for a good reference that will direct me in the design of these repads. CHeck out this thread I posted a long time ago.
http://www
Jorge L. Ramos, Jr., MSCE, PE
Alonso & Carus Iron Works, Inc. (www.alonsocarus.com)
Euro-American Steel Co., Inc. (www.euroamericansteel.com)
Joe Tank
That is a very, very unusual situation. Have you considered increasing the height of the anchot chair?
Joe Tank
