Eccentric reducer?
Eccentric reducer?
Has anyone ever heard of an eccentric reducer? I am looking for one to use on a sewer line so that I can slope the first part of the pipe @ 1/4" per foot and transition to 1/8" per foot further down. The fitting I'm thinking about looks like the one here:
http://ww w.weldbend .com/Fitti ngs/Concen tric%20&am p;%20Eccen tric%20Red ucers/stdc oncecc.htm
Also open to other suggestions for fittings to accomplish this. Any ideas? thanks in advance.
http://ww
RE: Eccentric reducer?
Contact a pipe fitting supplier in your area and present your situation to them, I am sure they will be able to offer an answer.
Regards.
As pennpiper mentioned, the "eccentric" reducer (as shown in Weld Bend site) is very standard and not a special application as you may be thinking. I am not from US but all pipe fitting manufacturers would be able to offer you reducers in either concentric or eccentric type. The basic speicifcation for the reducer is identical for both types, viz, large and small end nominal sizes, schedule, end prep etc.
Eccentric reducers are extensively used in any liquid transmission pipeline to avoid liquid pool formation in the lower corners of the concentric reducer when draining the line.
regards,
Thanks for the responses so far.
what type pipe end do you have on the CI, flange, hub or hubless?
If it is a hub end you can get the required slope with a double hub coupling. A hubless fitting is a little more challenging unless you have flexible fitting. With flanged pipe you can use wedge ring, flared fitting or built up box.
Here your flanged reducers.
http:/
http://www.metalfit.com/catpg12.html
