ARC-Fault Circuit Breakers
Not exactly a power question but I know I can get a good answer here.
The 2002 NEC requires arc fault circuit interupters in bedrooms of houses and hotels. The reason is that arcing fault start a lot of fires. Most of the time it's when there feeding unit heaters or electric blankets etc that people leave on when they are sleeping.
My question is will they open a circuit if they are feeding a device that arcs under normal conditions, for example hair dryers, refridgerators ( small ones in hotel rooms) or anything with a universal motor.
I don't know how the things work but I think they would have to sense noise on the circuit.
BJ Conner
BJ Conner
RE: ARC-Fault Circuit Breakers
There have been all sorts of discussions on these devices at http://www.electrical-contractor.net.
http://www.eaton.com/innovate/right1.html
http://www.geindustrial.com/cwc/products?pnlid=3&famid=8&catid=36&id=cb-qafci
for more info. The arc has to be an erratic discharge current.
