Note Deciphering
Note Deciphering
Note Deciphering
I am posting here as I am not sure what other Forum to place this in.  I have a drawing of a 1080 gallon tank, working pressure of 200psig, listed as a vertical air tank.  There are two flanged openings, and I have never worked with flanged openings before.  There is a note pointing to one of the openings that reads:
6"-150# R.F.S.O.
FLG. W/SCH. 80
PIPE X 7 5/8"LG.
What do letters in green mean?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
RE: Note Deciphering
It means "I don't want anyone to be able to read these letters on a purple background..."
I believe it means Raised-Face Slip On (a specific type of flange). Anyone, please correct me if I'm wrong... I'm not a flange expert.
A vendor of RFSO flanges:
http://www.industrialflange.com/flanges/raisedfacesliponpipeflanges.htm
V
Yes, RFSO Raised-Face Slip On. I would leave the periods off.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
I think there's a pressure vessel forum or similar, may have someone who knows for sure.
KENAT, probably the least qualified checker you'll ever meet...
Vc66, that makes good sense, thank you.
No problem! I've belonged to these boards for about 9 months now, and you're the first person I've helped!  hourglass
V
