Blind flange Calculations??
hello, i am trying to calculate some blind flange thicknesses but when i compare my values to those being used in B16.48, some thicknesses are off whereas others match up. I am currently using a yield strength of 38,000, gasket diameters from B16.20 & B16.21 and the equation:
t= d_g*(3P/16SEW)^.5 + c. Do you know what values are being used for the quality factor E? Also, should i only be using 90% of my yield strength? I am also using 0.05" for my corrosion allowance. Thanks in advance.
RE: Blind flange Calculations??
The formula you mention is correct as per B31.3, clause 304.5.3, formula (15).
The S value is selected from Table A-1 of B31.3 (not 90% of yield) and the E is selected from Table A-1A or A-1B (page 190, 191 of B31.3). Use the corrosion allowance as directed by your customer or use a value confirmed by a competent engineer, in accordance with the process requirements. In corrosive environment, the corrosion allowance would be most likely 1/8", not 0.05".
cheers,
gr2vessels
Remember that for a blind flange you must also check out the thickness required for the edge bending moment caused by the bolt loading not just use the equation you quote.
Why not just use the standard thickness from the flange code?
When I calculate the the thickness of flanges using pressure vessel code rules I always get thicker flnages than the flange codes but using less bolts/studs can get the thinkness down.
