Need help identifying a drafting symbol
4
I have a symbol on a mechanical drawing that I can't identify.  It is a circle with a slash through it. What does it represent? The drawing is dealing with measurements in mm for length/width etc.
RE: Need help identifying a drafting symbol
Does "Diameter" make sense?  Can you post an image?
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
Ø = diameter
Not to be confused with Greek letter Phi by our more scientifically minded friends.
"The diameter symbol in engineering, ⌀, is often incorrectly referred to as "phi". This symbol is used to indicate the diameter of a circular section, for example ⌀14 means the diameter of the circle is 14 units."  http://en.wikipedia.org/wiki/Phi_%28letter%29
KENAT, probably the least qualified checker you'll ever meet...
Great monkeydog, although it would appear to be an extract for the 1982 version or earlier, not that it makes a diff for the dia sympbol.
Kenat,
Not great enough for the coveted star?
If you have to ask, the answer is "no".
Sympathy star for monkeydog.
Thanks for giving the correct answer.  It was diameter (Nordic).
I'm not proud.
I'm and engineer.
Nope, and none of that sympathy star nonsense from me.winky smile
Mad deserves a star first if we're just giving them away  as he got the correct answer straight off, so here goes.
Too bad the time stamp doesn't display seconds, that could have been interesting to see how lagged TheTicks connection is.
Thanks for the Star.
Now that we've destroyed the purpose of stars on eng-tips, one for Tick since he actually inserted the proper symbol and made his statement definitively before monkeydog
Yea, Yea Tick did give the right answer, but he gave no backup documentation.
Sympathy star, random star, stolen star, make no difference to me, when I collect enough, I am trading them in for one of those foo-foo coffee's at Buckies.
You can trade your stars for coffee! Sweet!
<alt>0216 to get "Ø" (must use number pad)
Wow I had always wondered why I couldn't get those 4 digit characters to work on my pc, I didn't know you needed to use the number pad ☻ ☺ ☻ ☺ ☻ ☺
Tick -
Do you have a listing of other symbols accessed by the same methodolgy?
If you "heard" it on the internet, it's guilty until proven innocent. - DCS
° = <alt> 0176
± = <alt> 0177
square and cube are out there, but I never used them and forgot
TheTick,
   Thanks for Ø and ±.  I always wanted to know how to do those.
   Please note everyone, that on the TGML preview page, there is a "Click here" that shows you all sorts of TGML codes, not including the ones above.  TheTicks values work nicely.  Also, you can go to http://www.w3c.org, and read through the HTML standards to find more character codes.
                     JHG
squared² = <alt> 0178
cubed³ = <alt> 0179
Joe
SW Office 2006 SP5.1
P4 3.0Ghz 1GB
ATI FireGL X1
Alt codes are also quite easy to get from Character Map.  Start->Run and enter "charmap"
-handleman, CSWP (The new, easy test)
I found mine just by rooting around in the Character Map.  Also found in Windoze under "... --> Accessories --> System Tools"
JMarv,
   X23
   [ i ]X[ /i ] [ sup ]23[ /sup ]
   TGML codes are based on HTML.  A lot of stuff works.
                       JHG
If you click on the 'Process TGML' link when making a post, then click on the 'TGML Character Entity Reference' link in the window which opens up, the available special characters are shown. You can insert them in the way you would insert a smiley.
Can I have a star? tongue
             |                              ____.......__
             |\      .'           _.--""''``             ``''--._
      .._    |  \.' /  ..-''                                .-'
         '.             __...----""""""""""--..           \
         -         ..-''                       ``""-._     \
       .'  _.      \                                  `"-   \
      _.-'` |  /-.  \                                    `-. \
You must be REALLY bored today, Tick.  You did it in less than 17 minutes which is quite impressive...
Copy --> Steal --> Paste
