Turning off element labels.
When I mesh, every element shows its real constant type, in my case, R#, when meshing, it gets quite annoying to see a ton of R# around, how do I turn these labels off? I've looked under symbols and what not but to no avail.
RE: Turning off element labels.
PlotControls -> Numbering -> Element Numbering by NONE (or / and show numbering by colors only).
If it's not your default behaviour, then almost certainly there is a command in the Ansys Start Directives File telling him to do so: I'd suggest to check in there...
