Best CAM practices
Best CAM practices
We are using Gibbs CAM now and I was looking for tips on the best practices for supplying our 3D models for programming. We can supply our programmer with SW part files but whats the best way to do that?
Give him a copy keep the original out of harms way what if a REV. is done. Just overwrite that copied file? Basicaly should that file for programing reference the orginal in case there is a REV. etc.? If thats even possbile? I suppose i could insert the "master" part into a part and supply that.
Grant
Applications Engineer
SW2008 X64 SP 3.1
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: Best CAM practices
I have not used Gibbs, maybe it would work the same.
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 06/08
ctopher's home (updated Apr 30, 2008)
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the be
