coal vs. steel
coal vs. steel
I'm looking at a Coal Processing facility that is having some structural problems. The building column bases are surrounded by coal debris. Will the coal breakdown the steel?..The steel is anywhere from 50 to 100 years old and is heavily coroded. The coal debris retains water so I'm sure that the water has alot to do with it. I was wondering if the coal itself was contributing to the section loss.
RE: coal vs. steel
Blacksmith
RE: coal vs. steel
Acid attack is feasible and will be effected through standing water. It may affect also to concrete and its reinforcement.
