UG-NX-4 => how to create a Tool library (Tool database)?
I want to create a tool library,
So that I can retrieve a set of tools from the library for a particular operation
Example (Requirement):
Tool data ------ set 1=> a) 50dia R3.0 FL 50 TL 100
b) 20dia R0.8 FL 30 TL 80
------ set 2=> a) 45dia R3.0 FL 50 TL 95
b) 10dia R5.0 FL 20 TL 55
c) 12dia R1.0 FL 20 TL 50
------ set 3=> a) 50dia R3.0 FL 50 TL 100
c) 22dia R3.0 FL 50 TL 85
d) 18dia R0.5 FL 30 TL 75
Plz Help Me.,,,,
Plz Help Me.,,,,
RE: UG-NX-4 => how to create a Tool library (Tool database)?
or
add the list of tools in the tool library dat file, in the same format
Create a carrier for each "set" and then add the tools as you described.
From the operation navigator select the carrier and select object - template setting - template
For the tools set the template setting to load with parent.
Save the file
Now in another file when you want to retrieve the tools select create tool and select browse and pick the part with the tools. You will see the carriers on the create tool dialog. When you pick on of the carrier "sets" all the tools will be loaded with the parent(template) object.
Check out the help docs section on customizing the CAM environment
John Joyce
Tata Technologies iKS
1675 Larimer St.
Denver, CO
www.myigetit.com
